I am attempting to capture using a Leadtek WinFast TV 2000 XP card using MPEG-2 for video (which is fine) and MPEG-1 for audio (layer II at 48 kHz) so that I can go directly to DVD. Trying to archive old VHS tapes to DVD+R/W. It seems that the codec for MPEG-1 layer II can't be changed from 44.1 kHz to 48 kHz.
Anyone else had this problem and come up with a solution - i.e. different codec, or registry change so that the codec used by the TV 2000 XP card can capture audio at 48 kHZ.
Thanks for any help - ALewis.
What does Leadtek technical support say?
Panasonic DMR-ES45VS, keep those discs a burnin' -
Oh! yes tried Leadtek support - email and phone call - noTHING - NADA!!
A. Lewis
Is a 44.1 KHz audio capture OK for a compliant DVD?
By c627627 in forum Capturing and VCRReplies: 8Last Post: 23rd Mar 2010, 05:29 -
where are the mpeg layer 3 options?
By uglijimus in forum Video ConversionReplies: 15Last Post: 17th Oct 2009, 01:56 -
capture of S-Video and PCM 44.1 kHz at the same time ?
By nidi in forum Capturing and VCRReplies: 16Last Post: 23rd Apr 2008, 15:16 -
On the fly versus MPEG encoding
By moorthy in forum Capturing and VCRReplies: 9Last Post: 26th Jun 2007, 13:18 -
24/96 khz
By mikee55 in forum AudioReplies: 3Last Post: 10th May 2007, 11:39
