I finished converting the first half of the movie Scooby Doo fine and plays well, but the second half when I start converting it on TMPG the video turns green and pinkish purplish while its converting. The video plays fine as an AVI, anyone got any suggestions?
This is what it looks like:
http://wwfmarksaregay.netfirms.com/Image2.gif
Try this
TMPGEnc
Select options > environmental settings
click the VFAPI plug-in tab
right click the "DirectDraw" and select higher priority, do this several times until its at the top with a value of 4
I thought Scooby Doo was green and pinkish purplish , or is my eyes going
Oh, I just looked, you need to remove the bad frames using Vdub before you convert
load AVI into Vdub and scan for bad frames.
Video > Scan video stream for errors
If it finds bad frames,
Video >Direct Stream Copy and
Audio > Direct Stream Copy and
SAVE AS, save out another copy of AVI
Oh, and if Vdub crashes on the scan, download vdub-mp3-freeze.exe and use that to scan for the bad frames. c:\badframes.log
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 12:05 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 08:14 -
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 16:46 -
Lipsync-problem with copy of authored DVD (TMPG-related)
By fedet123 in forum Authoring (DVD)Replies: 2Last Post: 10th Oct 2009, 19:01 -
TMPG plus vs. free version
By bellyting in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2007, 01:11
