Trying to find out which software to use for SVCD .cue/.bin extraction, so I can go ahead and use the VCD header 'trick' to allow it to play on my Sony DVD.??
I have tried changing header using MpegTools in TMPGEnc for Centropy Spiderman SVCD, Disc 2 result 330Mb file when original is 726Mb ?? this was originally extraced using VCDGear with Fix Mpeg option enabled.??
Have I messed up in the extraction?
Can anyone help with these 2?
The centropy SVCD disc 2 image is damaged and the TmpGenc re-multiplex trick does not work. I tried without success, your only real options are watch on the comp or re-encode. Sorry
If you want to extract the file to re-encode it, either use VCDGear (do a bin -> Mpg conversion) or use IsoBuster and extract the files.
All are available in the TOOLS section~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
