I am attempting my first SVCD and noticed that the end product (after converting with TMPGE) leaves a Tic-Tac-Toe type square box in the top right corner.
Is this normal ?
What does it Mean?
Can it be removed?
"Today is only yesterdays tomorrow"
With mine it was a sign of the Elecard MPEG2 Video Decoder, I installed windvd and then uninstalled the elecard and everything was fine.
Hope this helps....
like slopoke said, that box is from the elecard mepg 2 decoder. Don't bother replacing the decoder if you don't want to though as the box will not appear when you burn an SVCD and play it on a standalone player.
VirtualDub filter to insert video from another source into a corner?
By Riothamus in forum EditingReplies: 2Last Post: 6th Jun 2011, 08:51 -
VirtualDub + Crop Filter adds a black border in right corner of video?
By CactusMan in forum Newbie / General discussionsReplies: 5Last Post: 17th Jan 2010, 09:24 -
Zoom / Small blue box bottom right corner of screen on Philips DVP-3252
By DVP-32 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 25th Jul 2008, 15:34 -
Vobsub causing pixelation on upper RH corner?
By Uzysuicide in forum SubtitleReplies: 2Last Post: 7th Feb 2008, 18:13 -
My DivX movies randomly blocking up only in the upper-right corner... (pic)
By sofakng in forum Newbie / General discussionsReplies: 6Last Post: 9th May 2007, 16:21
