Whenever I convert an AVI to MPEG-1 and try to burn it with Nero 5.5, I get an error when it finishes checking the file that says the file I just made isn't VCD 2.0 compatible. OF course I just turn off 2.0 compliance in Nero and burn anyway and I haven't had any problems viewing the VCD, but seeing that error every time makes me wonder what I'm doing wrong. Especially since the settings are all set to make a compliant VCD. I'm setting it up in TMPEG with: 44khz audio, 352X240, 29.97fps. I do leave the aspect ratio set at VGA 1:1 since (knock-on-wood) I haven't had any problems with that yet. Also, in the Systems options, I leave the stream output type as MPEG-1 because isn't an MPEG-1 file that meets all the specifications for VCD actually a VCD?
If anybody knows let me know
In TEMPEnc there is a button (i'm talking about 12A here), middle button of the three located in the bottom right hand corner. It is labelled LOAD. Click this and select the VCD MPEG compatable with either NTSC or PAL.
unless you select this option you are just creating a compressed MPEG version of your movie, without the VCD compliancy added.
Hope this helps
Something better Tmpeg Enc
By 02fx4dude in forum Video ConversionReplies: 4Last Post: 15th Aug 2007, 06:23 -
Tmpeg 2.5 will not encode .avi
By WuTangDvD in forum Newbie / General discussionsReplies: 9Last Post: 20th Jul 2007, 13:01 -
Trouble with TMPEG DVD Author
By acidcrash in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 04:31 -
Tmpeg enc Plus 2.5 selects wrong Aspect ratio
By wozmac in forum Video ConversionReplies: 6Last Post: 15th Jul 2007, 17:31
