HelloI was just wondering if it is possible to buy/burn a vcd onto a 3" cd? The cd's hold 180mb and if they follow the rule, should play around 18 minutes? I never herd of them until this morning, but i found out about them at http://www.cd-rom-works.com/3inch_cd.htm
Has anyone tried/got a vcd on one of these? they fit in dvd players, because my friend said they fit on a little ring.
It should work, as the directory is held on the inner edge of the disc.
You shouldn't need a a ring, as most players (if not all) have a slight depression for inserting these discs. If it is not a horizontally mounted drive you will need a holder. I have seen writeable credit card shaped CDs too, used for promotional purposes. and other shaped CDs, such as teddies and hearts, but that's a bit sad. -
Yep it works fine to burn vcd and svcd on them, they work exactly as ordinary cdrs.
My portable DVD player hates spinning up those little suckers with anything but CD-DA audio on them.
I bought a pack of Verbatim mini-cdrs. They cost twice as much as a 700mb and hold as fraction as much. But they look so cool that everyone needs at least a few. I loaded mp3s onto one and my mp3cd player and standalone player have no troubles with it. I see no reason why a VCD would not work. I wonder how much video you could fit on this using miniDVD!? a few minutes?
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 17:27 -
Matrox MX02 Mini or Matrox MX02 Mini Max
By Cingular in forum Capturing and VCRReplies: 0Last Post: 14th Oct 2009, 20:27 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 02:18 -
Hd Mini dv tapes via SD mini DV camcorder
By imptech3 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 02:11
