I've set the Play button, default in TSCV, to start playing the movie when the play button is pressed but it doesn't respond. All the other buttons work the way I want them too but not the play button. Could there be something wrong with the XML file or is it that my Apex AD-1500 won't recognize this command? Please let me know. Thanks
There is no button referable to a VCD called the "play" button.
There is a button called the "default" button that is often mapped as "play" on a DVD remote.
Perhaps, this simply isn't the case with your player. Hunt around your remote... is there a button called "default"?
Regards.Michael Tam
w: Morsels of Evidence -
Nope, no buton called teh default. It's an Apex AD-1500. The button is referred to as Enter/Play. I checked the XML code and can't find anything that would prevent it from playing properly. Maybe I need to get a different programmable remote or a different DVD player.
Just try pressing all the buttons first...
Perhaps it has been mapped to some obscure button (and hasn't been named as such).
Regards.Michael Tam
Why does one dvd made with ConvertXtoDVD play and another doesn't?
By Hal05154 in forum Authoring (DVD)Replies: 6Last Post: 26th Mar 2011, 00:29 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
menu button didn't work
By pcb in forum Authoring (DVD)Replies: 6Last Post: 13th Oct 2010, 16:07 -
DVD Architect 3.0 - Next button does not work right
By the soundsmith in forum Authoring (DVD)Replies: 0Last Post: 11th Oct 2009, 13:44 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58
