So...please tell me which program you feel is the best and more reliable for burning VCD`s with Windows XP........![]()
I have no problem with a range of programs, including
1) my preferred Nero - works perfectly but a simple VCD structure
2) VCDEasy - a bit painful to use for menus but flexible.
3) Easy CD Creator fine but I don't own it
4) CloneCD - great for copying CD's - main one I use for VCDs
5) native VCDImage for most flexibility in creating VCD, but you have to edit your own XML, and then use CDRDAO for burning CD
Note I use Windows XP and 2000 and both work equally fine (all latest updates via Windows Update installed and latest version of programs, except CloneCD) -
Success with both Nero and Roxio CD Creator (note: do NOT attempt to install an Adaptec version of CD Creator on XP... bad things happen).
Haven't tried much else. I have noticed that a lot of the freeware burning ware mentioned in the guides here hasn't worked. Something about the drivers I have installed. I really don't feel like messing with it, since the above named software works fine.
When it comes to XP, just think: Windows 2000 stability mixed with Windows ME device compatiblity... almost.
And to contradict myself almost immediately, there's a general rule of "if it works with Windows 2000, it will then definitely work with XP".
Both theories fail me on a pretty regular basis, so I probably shoulda just ended this post a few paragraphs ago. Oh well... -
Ulead Video Studio 6 (with both of the released patches) works great in XP to open my MPEG-2 cable TV captures and edit/encode/add menu and chapter points/burn VCDs (or SVCDs).
UVS6 is also ideal for me because I am extremely lazy and am thus drawn to integrated applications, rather than juggle an assortment of different apps, even if I have to sacrifice a smidgen of quality as the price of my sloth.
UVS5 (bundled with my vid card; UVS6 was a $50 to upgrade from UVS5) gave me trouble now and then under98SE, UVS6/98SE was better, but UVS6/XP has made me a happy camper, with satisfactory quality and pretty fast encoding time (~2x for VCD, ~4x for SVCD), and has not froze up or crashed (or even made a coaster) yet.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Unusual codec - French origin??
By pooksahib in forum Video ConversionReplies: 3Last Post: 17th May 2011, 01:41 -
Unusual bluray format problem
By mysts in forum Authoring (Blu-ray)Replies: 0Last Post: 14th May 2011, 12:50 -
DVD to m4v, Unusual Artifact??
By Galadirith in forum Video ConversionReplies: 0Last Post: 20th Sep 2010, 17:05 -
Unusual behavior of PC clock
By Seeker47 in forum ComputerReplies: 7Last Post: 22nd Aug 2009, 13:34 -
Unusual Raid Problem
By mysts in forum ComputerReplies: 6Last Post: 27th Apr 2008, 20:52
