    Mar 2002
    Berlin
    I try to open a movie file and get this error message: ASF:illegal object fragment flags 86 in packet at 3783ae2 packet size=1999, pp=10ff, send time: 14:48. Please help me I don't knnow what to do.
    Greetings Hanselel[/b]
    Mar 2002
    Berlin
    I forget something, the file I try to open is an asf file, which is trying to tell me that it is an mpg file. I also tried to download asftools but the download doesn't work. I downloaded a few cutter and they are all telling me that I have a wrong mpg file. The file i try to convert is the 15th episode of Berserk. Olease help me I really need your help with that.
    Greetings hanselel
  3. Most likely your error is that the ASF file is corrupted.
    Please note that VirtualDub 1.3c will not handle all ASF files properly so this is a possible problem. VirtualDub 1.3c predates save ASF formating and wont handle them.
    I suggest you try ASFTools, sorry can't help you locate them (try a web search).
    Otherwise redownload the file.
  4. Banned
    Jun 2001
    UK
    TMPGEnc will convert ASF movies... But if you want to have some fun use this tool http://www.digital-digest.com/dvd/downloads/graphedit.html
    Mar 2002
    Berlin
    I downloaded it, but I don't know what to do with it. And I still can't download ASFtools, it always downloads a html-document.
    Greetings Hanselel
  6. Banned
    Jun 2001
    UK
    Greetings Hanselel
    If your using a download accelerator you need to switch it off.
    As the the use of Graph edit;
    1) Use the File->RenderFile menu option to load in a file.
    : : 2) Remove the last two "filters" (or software components) from the graph. These default to your sound card driver and your video card driver. We don't want that, we want to convert to a different file format.
    : : We'll do AVI, because that's what you'll want if you're using AVI editors to edit the movie.
    : : 1) Use the File->RenderFile option and choose your ASF file (can use WMV, etc)
    : : 2) The default graph is built for you
    : : 3) Delete any filters after (but not including) the Windows Media Audio Decoder filter
    : : 4) Delete any filters after (but not including) the ASF ICM Handler filter
    : : 4) Insert a new filter (Graph->InsertFilters) called "AVI Mux" from the DirectShow filters section
    : : 5) Link the ASF ACM Out to XForm In of Windows Media Audio Decoder
    : : 6) Link XForm Out of Windows Media Audio Decoder to Input 1 of AVI Mux
    : : 7) Link ASF ICM Out to Input 2 of AVI Mux.
    : : 8) Insert a new filter called "File writer" from DirectShow section and choose a file name
    : : 9) Link the AVI Out of AVI Mux to the In of your file writer
    : : 10) Right-click the AVI Mux filter and choose Properties
    : : 11) Choose the Full option of the Interleaving section and click OK (this makes the sound and video match up and is the whole point of the AVI format)
    : : 10) Press the play button
    : : 11) Wait until the play button is active again - this means the thing is finished (you can right-click on AVI Mux and look at the Current Position and Duration count to see how far in seconds the conversion has progressed during the conversion)
    : : 12) Have fun editing your AVI
    Why not use TMPGEnc ?
