I'm trying to encode Star Wars I: Phantom Menace. Every frame is encoded in english and then Spanish immediately follows...no subtitles. Is there a way to cut out the Spanish version? Maybe a certain vob file needs to be cut or is it possible to strip the mixed spanish version via de-multiplexing? I also encoutered a similar problem with "Planet of the Apes" when it got a little square in the screen of the director with his commentary. I'm using DVD Decrypter, DVD2AVI and TMPenc.
theres an prog here called ifoedit...using this is a must...
it will strip out all subtitles and other lang packs....are u
burning to cdr or dvd??newer movies over 2hrs usually
go over 4.5g limit,EVEN AFTER STRIPPING EVERYTHING U CAN
Header stripping
By NikkiSix in forum Newbie / General discussionsReplies: 46Last Post: 17th Feb 2013, 17:57 -
Good Languages vs. Bad Languages?
By hech54 in forum FeedbackReplies: 8Last Post: 17th Mar 2012, 13:56 -
Multiple audio languages and subtitle languages
By BobAchgill in forum Authoring (DVD)Replies: 4Last Post: 15th Aug 2009, 12:44 -
stripping audio
By lou41888 in forum AudioReplies: 7Last Post: 5th Nov 2008, 18:46 -
cd-rom stripping
By marinebc11 in forum MacReplies: 4Last Post: 16th Feb 2008, 08:51
