I'd just like to know if it is normal that a North American DVD player does not play PAL SVCDs or if that would just be specific to some models (I got a cheap LenoxxSound DVD player, it's cheaper than the apex and plays all VCDs and NTSC SVCDs but for some reason the PAL SVCDs play for like 2-3 seconds then they stop. AHH!)
Thanks.
Not necessarily normal. Apex 1500 & Phlips 711 work fine playing the vcdimager PAL test disc on NTSC tv
Panasonic DMR-ES45VS, keep those discs a burnin'
JVC SR-W5U (PAL support?)
By VCRcomp in forum RestorationReplies: 12Last Post: 17th Nov 2022, 21:24 -
Looking for SVHS PAL capture device with timecode support
By nf42day in forum Capturing and VCRReplies: 2Last Post: 14th Jun 2011, 15:43 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
PAL SVCD - Optimal resolution for preserved aspect ratio?
By Gew in forum Authoring (VCD/SVCD)Replies: 7Last Post: 27th Feb 2009, 15:25 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
