    Feb 2001
    Michigan
    I have Scooby Doo in bin/cue format that i burned onto a CD with CDRWin. It doesn't play on my DVD player because i'm guessing i didn't use Nero to burn it like i usually do. How can i convert the now made SVCD back into something that Nero can burn it as a SVCD for me? Does that make sense?
  2. Extract the mpeg from the original bin file using isobuster. (search on google to find it). OPen the iso, go to the mpegav directory, select the avseq001.mpg file, right click and select extract but filter mpg frames (or something like that!) Give the resultant file to nero as your SVCD mpeg and burn!!
    Hope this helps
