I am trying to convert Divx files using Virtualdub, is there any way of getting better quality MP3 encoding than - 56k at 22khz, thats all my system will give me, seems quite poor... any codec suggestions....
I know i can do this outside of virtualdub, but i would prefer to do it inside...
are you using XP, isn't that the rate limit of the XP built-in codec? Sounds to me like you need to find and install a better mp3 codec. Try the Nimo codec pack in the tools section.
Nimo what's that
Once you have done the above, you might like to save out the WAV and load into www.goldwave.com (With MP3 plug-ins) and edit the sound (Maximize) check right and left channels are the same etc.. -
I think thats like the 4th post in a row where I seen you recommending goldwave. Do you work for them ?Originally Posted by KingJohn
Actually goldwave IS a great program, I think ive had it since win3.11 -
GoldWave is the original WAV editor, I have used it since Windows 386
there have been many clones since, but I continue to support it.
Windows 3.11 for work groups was much better, you could even Network
VirtualDub - Editing and Fixing Sound
By bpatters69 in forum EditingReplies: 1Last Post: 26th Oct 2009, 12:33 -
problems adding 5.1 sound using virtualdub mod??
By pete7769 in forum AudioReplies: 4Last Post: 24th Jul 2009, 15:45 -
Virtualdub and sound problem
By Shabaman in forum Capturing and VCRReplies: 0Last Post: 29th Feb 2008, 08:55 -
Virtualdub used with or without AviCutter=Sound Synch Problem
By johnharlin in forum EditingReplies: 11Last Post: 29th Dec 2007, 11:13 -
VirtualDub can't decompress the sound.
By KOJV in forum Newbie / General discussionsReplies: 5Last Post: 12th Jun 2007, 18:59
