I want to know how to get my VCR to play a pal tape sent to me by someone in the UK. when i try to play it the picture is scrambled and the sound plays fast. I'm in the U.S. and my VCR is made by DAEWOO. if anyone can help, plese respond. thank you
If you are living in the usa you will have a ntsc video recorder which only plays ntsc tapes. You need a multi system recorder to play pal or secam tapes.
Your solution is to get the tape professionally converted from pal to ntsc.
Alternatively transfer it to vcd if you have the means and then record it back to tape.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
Convert PAL to NTSC?
By killerteengohan in forum Video ConversionReplies: 32Last Post: 7th Feb 2012, 12:33 -
How to Convert NTSC to PAL
By Gusto747 in forum Video ConversionReplies: 14Last Post: 19th Aug 2010, 20:52 -
By rock.freak667 in forum DVD RippingReplies: 8Last Post: 21st Jul 2009, 09:16 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45
