Hello,
I am trying to convert some anime files from divx to vcd.
I use Virtualdub for the audio and tmpeg for the video, as described in the newsbie guide found here on vcdhelp.
I choose ntsc film vcd from the tmpeg's settings because the frame rate of the videos is 23,976. The final mpeg file is fine if I play it on the PC monitor, but when I play it in my television with my DVD player (Panasonic RV31) the picture is a little cropped on the left and right and I loose some subtitles. I have tried other tmpeg settings but the final picture on tv is always cropped.
Any help?
Under Settings -> Advanced, check your Video Arrange settting. If the original divx has no cropping, then usually centered, keep aspect ratio will work.
Also check that Crop isn't accidently selected from some previous encoding.
Sony Vegas Movie Studio 9 Platinum: Event pan/crop keyframing problem
By Dude E. O'Loo in forum EditingReplies: 2Last Post: 22nd Jan 2012, 19:09 -
Help with Strange Problem?
By Mitchum22 in forum Newbie / General discussionsReplies: 4Last Post: 21st Jun 2010, 22:10 -
Vegas problem with pan/crop dialog box
By lgh529 in forum EditingReplies: 3Last Post: 8th May 2010, 04:39 -
Event crop in Sony Vegas creates a strange effect
By Srivas in forum EditingReplies: 5Last Post: 23rd Mar 2008, 22:23 -
Problem with Saving Parameters in Pan/Crop.
By solarblast in forum EditingReplies: 2Last Post: 11th Jan 2008, 18:54
