Hi
I was encoding a DivX Movie and in the 70% i receive a message saying that there was a streaming error, how can i fix this?
thanks,
Check the Divx for bad frames with Vdub, if it finds any, save out another copy using Video > Direct stream copy Audio > Direct stream copy
I had a similar problem. My video drive is formatted at NTFS and my C drive is Fat 32. So in tmpGenc it was saving the temp files to c:\ and locking up do to the 2 gig file limit? Well I changed it in Option/environmental to my e:\ drive and that seams to have solved it.
Hope that helps -
hi
i check with VirtualDub for bad frames and it says that the DivX doesn't have bad frames, but has 0 frames undecodable..mmm not sure what this means.
It means there is nothing wrong, however... Since you know there is something wrongOriginally Posted by Steveharris
I would save out another copy anyway.
SAVE AVI -
great thanks very much, i hate to be a newbie
but everyone was a newbie sometime
I will save another copy then. -
Well since progress forces changes everyday, it is not possible to become anything other than a newbieOriginally Posted by Steveharris
Need Windows streaming encoder for Quicktime/Darwin streaming server?
By The village idiot in forum Video Streaming DownloadingReplies: 0Last Post: 10th Feb 2012, 15:50 -
I want to make a streaming server for streaming into a PHP/HTML site
By cassiell2085 in forum Video Streaming DownloadingReplies: 0Last Post: 31st Jan 2012, 10:23 -
Intermitent failure when streaming from MS Media Streaming Services
By OshiDaro in forum Video Streaming DownloadingReplies: 0Last Post: 8th Dec 2010, 08:10
