Main problem:
I can easely capture, with multimedia certer 7.1, in AVI, Mpeg-1 and Mpeg-2 format. When using AVI file format I convet it using TmpegEnc to Mpeg-2 and using VCDeasy I burn a SVCD that works ok in my DVD player. When capturing in Mpeg-1, VCDeasy burns a VCD 1.1 that works fine but,in VCD 2.0 doesn't work (sound is pulsing and image looks like a puzzle) what is rong? what I'm missing? The same occours when I capture in Mpeg-2. First the out put file is "myvideo.MP2" whitch VCDeasy doesn't recognize. I need to rename it to "myvideo.MPG" notice the extention. After renaming the file VCDeasy recognizes it but,
the SVCD won't work at the DVD player, same problem of VCD 2.0. I whant to distibrute my child videos to the grantparents who live 400 Km away.
SVCD is the beast format and easely duplicatebale. As Mpeg-2 format is only valid for 30 days in TMpegEnc I'm willing to use the Mpeg-2 capture files. I just whant a two fase process, i.e. capturing in Mpeg-2 and burn a CD.
By the way, why can I capture in Mpeg-2 and WMP doesn't recognize, where in my sistem is the codec? Is it a ability of my card?
Can you help me?
Thanks Sulik.
I'm gonna try, but I have a rage fury pro with mmc 7.1 and that mmc 7.7 is for rageon based cards. I hope it works. Let's try....
Creating an enhanced cd
By fokfokfok in forum Newbie / General discussionsReplies: 15Last Post: 26th May 2017, 22:05 -
Creating a forum
By beavereater in forum ComputerReplies: 10Last Post: 21st Apr 2009, 09:15 -
Creating Menu's
By wristar in forum Authoring (DVD)Replies: 4Last Post: 10th Oct 2007, 19:42 -
HELP With Creating AVCD
By BinaryJustin in forum Authoring (VCD/SVCD)Replies: 1Last Post: 4th Aug 2007, 11:38 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11
