My daughter has just gotten a DV camcorder. I don't have one. Is there a way that I can copy the tapes to my computer without a camcorder? Thanks.![]()
John Willetts
jjwilletts@adelphia.net -
Are you talking about the DV tapes or VHS tapes that were made from the DV camcorder?
You need a way to play the DV tapes (I assume you mean miniDV). There are decks available for this purpose (search Google with "miniDV VCR) but they are more expensive than buying a camcorder.
So, assuming you want to play the actual tapes, your best bet is to buy a camcorder. -
Perhaps your daughter could convert her DV captures to VideoCD, SVCD, DVD-R, etc? You could then watch those on your stand-alone DVD player (depending on the player, or at least you could watch them on your PC).
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Capturing HDV Tapes using a DV Camcorder
By Raz1 in forum Capturing and VCRReplies: 6Last Post: 18th May 2011, 15:49 -
Is my PC up to capturing from my camcorder?
By alhenderson in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 21st Sep 2009, 02:54 -
Capturing from DV Camcorder
By m baqar in forum Authoring (DVD)Replies: 1Last Post: 20th Apr 2008, 23:16 -
Does capturing with a camcorder really damage it?
By IL_video in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 22nd Nov 2007, 09:31 -
Capturing from camcorder
By Confused Chimp in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 13:09
