First off, let me tell you that I have read the guides in vcdhelp.com but I still have some Advanced, so to speak, questions.
I have captured an .avi using the PC-VCR utility of my Marvel G450eTV card. The avi is in YUY2 Matrox codec. I now want to encode it to VCD. (The .avi was captured off my VHS at 704x576 resolution)
I loaded the .avi into TMPGEnc and chose the on-board VCD template of TMPGEnc (is it any good BTW?). What I want to ask is how to configure the Advanced tab of the settings in VDub...
To be more specific, the guides say to use Non-Interlace (Progressive), Top Field First (field A), 1:1 VGA and Full Screen (Keep Aspect Ratio).
However the settings I used for encoding to SVCD up to now, where Interlace, Bottom Field First (field B), 4:3 625 line (PAL) and Video Arrange Method = Center
Which are the optimal settings for encoding to VCD which will be displayed on my TV afterwards.
Results 1 to 1 of 1
Captured AVI file too large
By drgt in forum Newbie / General discussionsReplies: 38Last Post: 29th Sep 2010, 07:22 -
Cleaning Up Captured AVI
By Candoo in forum Newbie / General discussionsReplies: 3Last Post: 17th Dec 2008, 13:29 -
Captured all my old home videos to AVI... now what?
By w@ntonsoup in forum Video ConversionReplies: 11Last Post: 26th Feb 2008, 18:05 -
when captured avi goes over 4 gigs nothing recognizes it ?
By 99teggsr in forum Capturing and VCRReplies: 11Last Post: 28th Dec 2007, 22:00 -
Ok, captured my video as AVI format
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 18th Jun 2007, 23:37
