Hi, i have files that i cant open. Specifically avi files which when i try to view in WMP it says "cannot play back file. format is not supported." I have the divx codecs installed and nimo as well. Whatelse can i install which mihght help me to view these avi files? The properties of this file are as follows:
Image- 640x272 pixels
Audio-MPEG Layer-3 at 144 kbps bit rate
Video- 23 frames/sec.
-4kbps data rate
-24bit video sample size
-DIVXMPG4 V3 video compression
I should add that i can see the video if i use the preview option in TMPEnc.
Hope this information helps to reveal my problem. Thank you for your help in advance!Excellent, wicked, awesome site btw to the powers that be. More information and helpful people than you can shake a stick at!
Nevermind.I wrote some stuff,but now realize It was something entirely different.
Hundreds of thousands may lose Internet in July
By TreeTops in forum Off topicReplies: 4Last Post: 21st Apr 2012, 21:49 -
Question about rip/writing times....
By tcory in forum DVD RippingReplies: 2Last Post: 4th Jan 2011, 22:13 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 18:28 -
Adding subtitles (srry if youve answered it many times)
By hellfire662 in forum SubtitleReplies: 4Last Post: 16th Sep 2007, 12:01 -
Suggestion for converting hundreds of mov quicktime files
By m021478 in forum Video ConversionReplies: 0Last Post: 15th Aug 2007, 15:16
