Well just started using TMPG to try to encode, previously I was using LXS but only have the light version and cant control output res etc and want to get on the CVD wagon (well 1/2 D1 DVD wagon really). I'm using a DV500+ and Premier 6.01 to capture.
Here's my thing, tried a test capture and encode of a cartoon, interlaced capture, and interlaced output from encode. There seemed to be the worst jaggies that I had ever seen in fast movement. I checked the field order and it was correct. any suggestions??
Later BRETT
Results 1 to 1 of 1
nVidia NTSC TV-Out interlaced field mix-up issue
By cybertheque in forum Software PlayingReplies: 3Last Post: 19th Dec 2011, 16:55 -
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 04:12 -
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 23:53 -
upper field or lower field first? how should I export from premiere
By phpmysql348 in forum EditingReplies: 2Last Post: 6th Sep 2008, 23:54 -
Top Field First to Bottom Field First
By boblin2 in forum Video ConversionReplies: 0Last Post: 6th Dec 2007, 00:19
