ok, i have tried usin the DVD2AVI DVD conversion guide and i got the dvd ripped onto the HD..then i use dvd2avi program and it does it and i have a file.d2v but when i go to open the program TMPGEnc i cant select a video output, my audio one works fine just the video part doesnt, and when i go down to the bottom, it says i might come across this program and it says to select another audio track in the program dvd2avi, i was wonderin how do to that, cuz there are like 2 different places where i can select different audio tracks, thanks for your time, hope you can help
1. Copy the VFAPI file in your DVD2Avi directory into your TMPGEnc directory.
2. Go into TMPGEnc's environmental settings and raise the priority of this DVD2Avi VFAPI.
3. Open the .d2v file as your video source.
4. Encode! -
ok for some reason i cant find the vpafi file anywhere, the site for dvd2avi file is down, i do have the file but i dont have the plug-in to get it, i was wondering where else i could find the file?
Just change the menu to "All Files" and choose the d2v file - that should work.
in tmpgenc, go to options, global settings. click on the "Vfapi plugins" tab, and see if there's a plugin called "Dvd2avi project file reader xxx". if you can't open d2vs, it's probably not. do a search on your comp for the file dvd2avi.vfp. move that into your tmpgenc dir, run a little install.bat file, and you should be good to go.
hey thanks for all of your guys help, i got it now, i just have to wait 5 hours for it to encode, appreciate all of you help
must read stories, 11-17-09
By deadrats in forum Off topicReplies: 1Last Post: 17th Nov 2009, 22:13 -
Microsoft- Please read!
By ahhaa in forum ComputerReplies: 9Last Post: 25th Feb 2009, 15:57 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04 -
Cannot read last title
By cyflyer in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Jun 2007, 19:55
