evening all.
PROBLEM:
I am trying a capture card on my 2nd pc, but am not able to get it
to work w/ AVI_IO or VDUB. Driver does show up under menu, but
when I go to select "Capture AVI" unfer File menu, I get the same
old error message: "ERROR 418: Capture device was not detected"
HARDWARE:
CAPTURE CARD:
* I/O Magic's PC PVR
This card says it's support win98SE/2000, etc.
However, my current system for both my pc's are Windows 98, but not
SE version.
INSTALLATIONS:
I/O Magic's PC PVR Card:
* I've installed the WDM drivers for this card w/out a hitch.
* I've also installed the VFW wrapper ( under win/system? )
* I've rebooted
REASON:
I want to give this card a try because it's the only card in it's price
range $39 that came with S-Video in addition to Composite RCA plugs.
But, my main reason for trying out this card was to see if this card
produces those same noise (lines) as my ATW card does. ...wanna see if
this is normal for all PCI capture cards.
Software Capture Apps:
* I'm D/L'ing iuVCR as I write this. I'm hoping that this app will work,
since it is designed for WDM drivers in mind, but so far, All I see is
win2000 and XP support, but nothing for any other OS.
OBJECTIVE:
My goal here is to be able to use this card to capture (AVI) under Windows 98.
I will continue to play around w/ this card in hopes I get it working.
Should I get it working, I'll post an update here, but I would like to
hear any other suggections, if there are any.
Thank you for your support.
-vhelp
Results 1 to 1 of 1
Trying to select PVR software for my capture card.
By GLE3 in forum Capturing and VCRReplies: 7Last Post: 14th Apr 2010, 18:03 -
HP TV Tuner/PVR unit ? or Black magic Intensity pro?
By TBoneit in forum Capturing and VCRReplies: 43Last Post: 11th Feb 2010, 09:35 -
Questions about using a Black Magic Intensity Pro card
By flyingplanet in forum Capturing and VCRReplies: 1Last Post: 10th Aug 2008, 21:15 -
Black magic PCIe Card help required.
By Canadian* in forum Video Streaming DownloadingReplies: 1Last Post: 10th Apr 2008, 01:49 -
Unable to capture from camcorder with WinTV-PVR 250 card and and WinTV2000
By forestial in forum Capturing and VCRReplies: 1Last Post: 29th Dec 2007, 19:00
