  1. Hi
    I am having trouble with Spider man svcd disc 2, it was released by Centropy. At first I couldnt run the file, so i tried to fix it with MPEG corrector. It worked I guessed, i could run the file, so I tried to make the image with VCDEasy, it said somthing about the file is not valid. Then i burned it with Nero, i ignored the standard stuff. The cd would not work on my DVD player, but it works on my computer. All it saids is Disc loading then VCD 2.0, and doesnt do anything. Please HELP!
    Thanks!
  2. A couple of things could be causing it to happen that you might wanna check.
    1) Make sure you burn the CD as a SVCD in Nero
    2) Use reliable media
    3) Make sure your player is compatible with both CD R/RW and SVCD
  3. Thanks man. I will try it.
  4. Banned
    Jun 2001
    UK
    Originally Posted by kennyken
    Hi
    Thanks!
    If you could not run the file then I guess you realized it was faulty, you then used a program to fix it, but did you fix it ?. Just because it plays does not mean it has no faults. In cases like this, I would re-encode the whole thing in TMPGEnc, which should fix any faults, before moving on to make a disk.
