Got a small problem, if anyone can help, it would be greatly appreciated.
When I try to svideo-out the video from my camcorder to the s-video-in on my tv, i get no picture. The svideo-in on the tv is input 1 and on vid1 there is no picture...the same goes for all the other channels.....I've tried many things, such as disconnecting all inputs to the tv besides the svideo-in, so as to avoid conflicts, still nothing...maybe someone who has knowledge on svideo tvs and is aware of certain specifications would be able to help me out?
thanks :P
Results 1 to 9 of 9
On some sets you have to goto the menu and select which video in to use...mine has a front, back...then regular cable...
What type of tv set is it? -
cushman over there has a high level mental handicap.
what he means is that its an RCA television. -
its basically this one: http://www.rca.com/product/viewdetail/0,2588,PI45922-CI104,00.html?
but the one there is a little more updated, mine doesnt have the jacks on the front of the tv. they're on the back. -
What is the model number of your RCA television?
I ask this so that I can go do a Google search for a PDF copy of your TV manual, and possibly find the solution to the problem. It wil probably turn out that the manual states that you tune your TV to some particular channel (i.e. 90,91,92 - RCAs are usually 90 - mine is) in order to get the S-Video input on screen. Or, there might be a menu option to select the S-Video input.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
scrolling picture problem with svideo
By slyder0244 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Jun 2009, 18:35 -
HDMI to Svideo or Composite?
By cdgtcc in forum DVB / IPTVReplies: 1Last Post: 14th Nov 2008, 04:53 -
SVIDEO Question
By jhorak101 in forum Newbie / General discussionsReplies: 3Last Post: 18th Jan 2008, 23:47 -
pc to tv svideo?
By xbill in forum Newbie / General discussionsReplies: 19Last Post: 15th Jan 2008, 10:31 -
Connecting my PC to TV via svideo.
By chronic777 in forum Software PlayingReplies: 2Last Post: 12th Sep 2007, 00:06
