I have a vcd that i have burned and it works fine on my standalone dvd player but when i put it in my cdrw drive and run cinematograph it doesnt work. I can load the .dat files fine but i want to be able to use the menu that i created for the vcd. I cant figure out what the problem is
hI
I also need help with my pc.My pc plays the vcd movies pentium pro 200Mhz 64 M Ram. But my picture crumble's the the movie hang. I the have to restart the pc can you help please. Do I need a vidoe driver file or other video card.
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 09:55 -
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 17:57 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 05:35 -
Is there any free VCD playing software which meets my requirement?
By csh in forum Software PlayingReplies: 11Last Post: 20th Dec 2007, 01:21 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 12:25
