HELP IS NEEDED?
I HAVE MADE MY MENU AND PUT MY FILM IN AND IT WORKS OK BUT?
I WANT TO PUT A CREATED BY ME JPG BEFORE THE MENU THEN PUT THE FILM AND 2 TRAILERS ON AFTER THE MENU. AND LAST A INSERT DISK 2 MPG IN BUT WHEN I PUT THIS ALL IN IT WILL PUT MY MADE BY ME AND INSET DISK 2 MPG IN THE MENU TO SELECT. ANYONE ONE HELP PLEASE
It's no problem with Nero, you can download the latest version of Nero Burning ROM 5.5.8.2 & SVCD_Pluging # Mp3Pro_Plugin from the F2390ree Download A23rea of [cut]
Listsen to me, if U indeed wanna get this software, you will have to remove all of numerals in this text, you will find
Firstly, this isn't even the problem. Secondly, do not link to warez on this forum -
If I understand correctly you want to add a screen before the menu appears using Nero (like an intro sequence). Unfortunately you cannot do this using Nero. The only way to do this is to use
1. Easy CD Creator Platinum (supports intos)
2 VCDEasy/VCDImager (freeware) but harder to use.
Can I use Nero to join DVD with menu?
By csh in forum EditingReplies: 3Last Post: 12th Nov 2007, 11:58 -
Need input with convertx2dvd and nero 7's menu builder
By MidnightMike in forum Authoring (DVD)Replies: 4Last Post: 9th Nov 2007, 14:48 -
Menu Music with Nero Vision
By Smudge249 in forum Authoring (DVD)Replies: 2Last Post: 7th Nov 2007, 06:09 -
Nero Vision 5 menu audio help?
By sls-sls in forum Authoring (DVD)Replies: 1Last Post: 31st Oct 2007, 13:26 -
Can chapters created in Nero 6 show up in menu?
By wayney in forum Authoring (DVD)Replies: 2Last Post: 15th Jun 2007, 12:46
