I have learned a bunch from reading this website and forums. Geat stuff.
I recently bought a ATI TV Wonder VE card and it captures TV video at 640x240 8mb sec, with 44k 16 bit audio as an mpg file.
I try to open the video file in premiere and get a error:
Unable to open that file.
File is an unsupported type.
I try to open the file in tmpeg and get a similar error:
"Cannot open or unsupported." I even bumped up the priority for the direct show multimedia in VFAPI and it still doesnt work.
Is there any video program that can open these mpg files?
I can play them just fine in Windvd, I just cant open them in any editor or conversion program.
has anyone else ran into this problem?
thanks
whiz
Its sounds like you are encoding in MPEG2, you might need a codec. If so then just encode in MPEG1 and up the bitrate a bit...
Thanks for the quick reply. I have divx5 codec installed, and the updated windows media player.
The ATI TV recorder doest specify a codec, just mpg or avi.
I tried a capture in avi format and got the same message. It does sound a like a codec may be missing , any idea which one?
I have all the standard ones show up in flaskmpeg, huffvey,cinepack,microsoft,divx etc..
thanks for any ideas
whiz -
Which MMC version are you using? The one supplied on disk or MMC 7.1 from ATI's website?
I am using mmc 7.1 , the updated one from the ATI website. I checked their support for any ideas and didnt see anything.
thanks for your help -
This may (or may not) help:
http://forum.vcdhelp.com/viewtopic.php?t=89375&highlight=ati+vcr+mmc+convert
p.s. Please fill out the "computer details" section of your board profile (click "profile" at the top of the page).As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
How to convert to .mpg without failing?
By Grahamf in forum ffmpegX general discussionReplies: 2Last Post: 27th Mar 2011, 19:36 -
need to convert mpg to avchd
By mrgreaper in forum Video ConversionReplies: 5Last Post: 14th Aug 2009, 10:49 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
how can i convert .mov to .mpg?
By johnnylonghair1 in forum MacReplies: 4Last Post: 6th Apr 2008, 12:30 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47
