HI, Someone help please![]()
Have a Yelo800 DVD player .. I cannot modify the colour/brightness of the picture when i use the scart output. This makes watching movies like Aliens impossible. Changing the settings on the TV has no effect AND i know the TV is ok because if i use a scart output from my new VHS player the picture can be altered in the normal way. I was wondering if anyone else had the same problem and is there a solution other than using the one of the other outputs.
I remember i once owned a TV (a GoldStar (LG)). If i used the RGB input from my DVD Player , the Colour/brightness/contrast settings were fixed, and could not be changed... (a quirk of the set apparently). If you can, change the output to composite, or use another scart socket on the TV if it has one. On two or three socketed sets, socket one is usually the only RGB capable one...
AHHHH yes thats it ... i changed the output to YUV (still using the scart cable) and the signal is now adjustable. The TV is a Sanyo and is some years old (1 Scart socket only) so that must be the reason.
Thank you very much indeed for your reply.
Connecting HDMI (Android Devbice) output to an RGB/SCART TV socket
By excelis4 in forum ComputerReplies: 0Last Post: 20th Nov 2011, 03:03 -
PC To Scart
By simonm95 in forum DVB / IPTVReplies: 5Last Post: 19th Jul 2009, 13:54 -
Is any difference in scart cables?
By szalaikornel in forum DVD & Blu-ray RecordersReplies: 1Last Post: 12th Feb 2009, 10:06 -
RF/SCART into computer
By michcio in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2008, 19:20 -
PC to RGB Scart
By jottery in forum ComputerReplies: 2Last Post: 13th Jan 2008, 15:01
