i installed nimo pack so i can play svcd on windows media player.the player still doesnt regognise the disc.is there something i should do or should it self extract?
You still need to download an mpeg2 codec to play SVCD but I would sugest that you instead use a software DVD player to play the files such as WinDVD or PowerDVD
do a search on google for mpeg2 codec download if you must...... -
How are you trying to play the disk ?, try opening the folder with the .dat file and double click it to play.Originally Posted by ianskill
What is the best Codec Pack?
By cim in forum Software PlayingReplies: 84Last Post: 8th Jul 2012, 12:45 -
Win7codecs pack
By jh443 in forum Video ConversionReplies: 1Last Post: 16th Oct 2011, 21:10 -
Installing XP on a used PC
By CSULB71 in forum ComputerReplies: 24Last Post: 21st Nov 2008, 12:05 -
error installing K-lite codec pack
By Shotobits in forum Newbie / General discussionsReplies: 4Last Post: 22nd Mar 2008, 03:38 -
installing
By lindakay in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 4th Mar 2008, 08:13
