Hi hope someone can help me out with this one.
I`m trying to convert a Divx I`ve download to DVD Mpeg. The first thing I normally do is load the Divx up into Virtualdub and then uncompress the audio and then split to audio and video to two files ready to convert with TMPG.
With this Divx I get the message
VirtualDub has detected an imporper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibilty. This may introduce upto 12688 ms of skew from the video stream. If this is unacceptable, decompress the entire audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder ( bitrate 140.9+- 15.7 kbps )
Can anyone explain what I`m suposed to do ?
Thanks in advance
Yes Ignore the error, as you wont be making a new DivX file
Audio > full processing mode
Audio > Conversion > 44.1Khz
SAVE WAV
Variable Bitrate or Constant Bitrate?
By i am x in forum Video ConversionReplies: 3Last Post: 12th Feb 2010, 08:49 -
Both constant bitrate and two press bitrate are the same,right?
By tendra in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 05:35 -
I need a constant bitrate
By alexv305 in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2008, 07:38 -
Variable and Constant bitrate ??
By VEBouto in forum Newbie / General discussionsReplies: 4Last Post: 18th Oct 2007, 00:56 -
How do you create Constant Bitrate DVD's?
By Undead Sega in forum Authoring (DVD)Replies: 12Last Post: 13th Oct 2007, 03:33
