Hi!
When I try to capture with VD with a resolution of more than 240 (height), I get "thin lines like a comb". I went to the VD web site. It says there that it is a interlacing problem -->
Q: "I see a lot of thin lines in my image, like a comb."
A: "That's interlacing -- what you're seeing is two fields, taken at slightly different times, and combined together to form a single frame. You'll see it whenever you capture with a height more than 240 lines (NTSC) or 288 lines (PAL). Interlacing is not a defect in the video and cannot be "fixed" -- it's a fundamental aspect of the way video is encoded. "
Is there a way to go around as I have seen many posts about others capturing with a higher resolution.
I will appreciate your help.
Thanks!
LD
PS: I capture from a Hi-8 camcorder (HUFFYUV codec )
Sound like you need to apply a deinterlace filter to your capture, though I'm surprised to hear that your source is analog video, which is not interlaced.
Anyway, if you need to deinterlace, VDub comes with deinterlace filters, which you can apply when you capture and/or convert (Video --> Filters). In my case, I got the best deinterlace results from the Area Deinterlace filter, which you can download into the VDub plugin directory from http://home.bip.net/gunnart/video/ You should also try (from the same site), the Smooth Deinterlace filter, though it didn't give me as good results as the area filter.
Good info about deinterlacing, at www.100fps.com
Interlacing problem?
By killerteengohan in forum DVD RippingReplies: 16Last Post: 18th Aug 2011, 06:24 -
De-interlacing problem?
By fredo2010 in forum Video ConversionReplies: 17Last Post: 27th Oct 2010, 15:48 -
Interlacing problem with Blu-Ray ?
By quantumfire in forum Authoring (Blu-ray)Replies: 9Last Post: 28th Jul 2009, 13:51 -
Good Video Explaining Interlacing and De-Interlacing
By Soopafresh in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2008, 19:50 -
problem with DV interlacing after editing
By cheeseplease in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 5th Oct 2007, 21:37
