Hi there. I am experiencing the following problem when frameserving from Premiere :
I have installed the Video Server plugin and everything is normal till I export the video from premiere. However, when TMPGEnc tries to pick up the served .avi (IRCServer.avi), it gives me an unsupported format error. ("File cannot open or unsupported").
What am I doing wrong ?
I have tried disabling the Direct SHow in VFAPI plugin but still no luck...
Any help ?
Checked your captured AVI format under capture settings?? Depending on if it is set to AVI 1.0 or not can cause problems (try changing it)
Later BRETT -
The captured AVI is in YUY2 Matrox format (I captured it with my Matrox G450eTV).
Is there an option under capture->movie->edit (settings)->settings that allows you to select AVI 1.0 or openDML ?? the above menu should give you your cards options control, if so try changing the setting.
Later BRETT
frameserving dvd to premiere to avoid demuxing, is it possible?
By codemaster in forum EditingReplies: 3Last Post: 7th Jan 2011, 16:11 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 20:57 -
Adobe Premiere problem ??
By 3thman in forum EditingReplies: 9Last Post: 1st Nov 2009, 18:23 -
frameserving movie from premiere pro cs3 to avisynth
By colin66 in forum Newbie / General discussionsReplies: 10Last Post: 29th Oct 2007, 08:47 -
Frameserving with Adobe Premiere to Procoder?
By Soulman in forum Newbie / General discussionsReplies: 3Last Post: 19th May 2007, 07:01
