please help i am trying to create a vcd from my home movies.
i have a sony digital cam and i am using pinnacle dv500 i have a yamaha s795 dvd player and i am using a yamaha burner. i have just about tried every program i can find i can burn the vcd with out any problems but it will not play in my dvd player, i have checked the player compatibility and it tells me i can play vcd,s on my unit plus i have played vcd,s that i have bought and they work fine. i'm just about ready to throw the dam thing out the window. i have read through the forums and checked the guides and i seem to be doing everything right but it still wont work.
please help me someone anyone please![]()
Try cd-rw they seem to be more compatible. try this for me burn a music cd and see if your dvd player accepts it. some players simply don't accept cdr.
#videohelp on dalnet! -
thakx for your replies i just tried using a music cd that i had recorded a while ago and your right it wont read.
does this mean its the dvd player or should i try using different media ?
or would i be better off just buying a dvd burner, is that easier to record home movie's to and playing in a dvd or could i have the same prob ?
again thankx -
you could have the same prob you can try different media. like i said cdrw's are often more compatible. dvdr might very well have the same prob. Try b4 you buy
Can't get DivX to work with AutoGK no matter what I do.
By teapot in forum Video ConversionReplies: 4Last Post: 17th Jun 2010, 23:38 -
Why wont subtitles work?
By .deathnet in forum SubtitleReplies: 2Last Post: 3rd Mar 2009, 13:01 -
Disc will/wont work between different DVD players.
By Scroogle in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Jan 2008, 15:41 -
SVCD2DVD 2.5.2725 Wont create dvd
By Stuart-ASI in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 21st Jun 2007, 19:54
