    Mar 2001
    Somewhere on planet earth
    I'm interested in using the menu portion of the DVD to use as part of a motion menu but can't find the program chain that corresponds to this. The one I'm interested in is Metropolis, good flick by the way. I ripped all the program chains and can't find it. Are there any other suggestion as to how I can go about this?
  2. Using SmartRipper, dont rip movie, but click on the back up button, all the files should be ripped and if any are missing you have unlocked the disc so any files you are missing you should be able to extract using explorer.
    You're not really going into an astroid field are you?!?
    They'd have to be crazy to follow me!
  3. usually using smartripper its that vob.0 where ur movie files are at that has menu...usually in the 200mg range or so depending on how new and complexed it is...........
