I need help trying to convert an avi to divx. I have done this before very well but now I’m dealing with an avi video produced from the ANSYS apps and I’m having no luck. I tried a two pass encoding with divx 4.xx and the movie looks distorted. I tried to convert to mpg resulting in a black video. Some of the vide information:
856x552, 10fps
29 frames in 0:02 sec
Microsoft Video 1 (decompressor)
It is a short simulation movie of a part receiving a load. It is 2.xxMB and I know I can compress it to 100kb or less with good quality using divx. Anyone willing to help please? Thanks.
FEA! I haven't used ANSYS in a long time (just a couple of consulting jobs a few years back), but I'll assume that you've already converted the anim file to an AVI (or it might do that on its own now - I have no idea - i used to have to use an app to do that in order to watch them in WMP).
Here's the "Animate" conversion app I used to use:
http://www.egr.msu.edu/decs/facilities/software/ansys/animate.exe
Give that a shot (if you haven't already) and see if it can't make that AVI into Windows-readable AVI. Best of luck!As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
The software u recommended seems to do exactly what ansys do. Anyway I worked around the problems. Looks like using filters makes the resulting video distorted. I tried first encoding to divx using 1 pass 2000kbps then using that avi I encoded using filters, 2 pass, etc. This way it works. Thanks for the help.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Can't convert avi to an avi that the my divx player will read.
By aarelovich in forum Video ConversionReplies: 5Last Post: 4th Feb 2010, 06:19 -
divx to avi with divx author
By pred in forum Video ConversionReplies: 4Last Post: 12th Nov 2008, 23:32 -
avi to DivX using divX converter pro
By Deaf Raiders in forum Video ConversionReplies: 3Last Post: 19th Dec 2007, 13:28 -
Convert this avi to DivX avi (GSpot Screenshot included)
By indiannawaf in forum Newbie / General discussionsReplies: 13Last Post: 22nd Aug 2007, 11:26
