I keep getting this message when i add a file when trying to create a SVCD...
themovie.mpg:
Warning: consider enabling the 'update scan offsets' option, if it is not enabled already!
I also get this in the Log when creating my SVCD image
mpeg user scan data: one or more BCD fields out of range for 'backward_I_offset': [00:07.2f] (i get several messages similar to this)
mpeg user scan data: from now on, scan information data errors will not be reported anymore---consider enabling the 'update scan offsets' option, if it is not enabled already!
what's the deal with this, and should i enable that option?
Thanks!
Mojo
Results 1 to 1 of 1
AutoMKV hangs with message "first normalizing volume - WAIT" message :(
By Jackie78 in forum Video ConversionReplies: 1Last Post: 25th Dec 2011, 06:33 -
Odd BD Rebuilder error message
By robvalentino81 in forum Blu-ray RippingReplies: 2Last Post: 21st Sep 2011, 11:08 -
Odd slowness
By Lucifers_Ghost in forum ComputerReplies: 12Last Post: 22nd Jan 2009, 19:08 -
odd message from Toast while burning DIVX/XVID
By muttonhead in forum MacReplies: 6Last Post: 11th Sep 2008, 19:23 -
Space requred seems odd
By jriker in forum RestorationReplies: 2Last Post: 2nd Feb 2008, 12:45
