Alright mateys, lookie here.
Assume that I have a particular AVI file which I have extracted from my DV Cam recording. However, due to some copyright protection limitations, the AVI file which I have extracted is completely dumb.. Or rather, mute without any sound.
Fortunately, I've managed to extract the audio that should have complemented the video into a wave file (courtesy of Total Recorder) and now I'm trying to merge the wave audio with the AVI so as to achieve an end-product which I can burn into a VCD.
I was wondering what processes and software would you all recommend in order to achieve this? Would appreciate some enlightening advice indeed, and thanks a lot beforehand ^^
Cheerio,
Theodore Massacre
you can use the tempgenc program loacted somewhere on this site. when the program is loaded you can choose the audio and video source separately and the prog merges them together. that should solve your problems. hope this helps.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 08:39 -
Merging multiple parts of one mp4 file into one file
By vaultedskies in forum Newbie / General discussionsReplies: 2Last Post: 16th Nov 2011, 10:08 -
Merging audio file and video file using ffmpeg
By suresh3484 in forum ffmpegX general discussionReplies: 3Last Post: 17th Aug 2008, 22:20 -
Help on merging h264 and aac file
By overground55 in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2008, 14:23 -
By suresh3484 in forum ffmpegX general discussionReplies: 0Last Post: 27th May 2008, 04:05
