i have a ASF movie file, how can i convert it?
-JMH
Results 1 to 10 of 10
i need to find an older version. they removed support for it because microsoft owns the patents for it, and the had to take it out to avoid issues.
Just look around, I have the new and old versions, I got the old one later, so if you look around you should be able to find it. I'm not positive I remember where I got it from though. Try ZDNet or sumthing.
You're not really going into an astroid field are you?!?
They'd have to be crazy to follow me! -
This is not a hack just an old version (1.3c) and the last to suport the asf before the Gates army crackdown.
http://www.grabber.pwp.blueyonder.co.uk/html/software.html
Click on virtual dub -
Or better still
http://forum.vcdhelp.com/viewtopic.php?t=98704&highlight=graphedit
Or even use the New TMPGEnc, it eats ASF movies 8) -
TMPGEnc has always supported asf-movies (using its DirectShow filter) as far as I know.
In my experience, the main problem with converting asf-files is that TMPGEnc has problems with reading the sound of the asf-file and will hang. The solution that works for me is to first extract the soundtrack of the asf-file to a wav-file, using dbPowerAmp (http://www.dbpoweramp.com/). Then it's possible to use the asf-file as video source and the wav-file as sound source in TMPGEnc, and all problems should be gone. -
I just went and downloaded the latest TMPG...And there must be a trick to making it open asf files.....cause mine won't.
Under "Option > Environmental Setting > VFAPI Plug-in" give the highest priority to the "DirectShow Multimedia File Reader".
What does it say ? or if there is a black screen then see above post, if not, you need to install the Nimo codec pack.Originally Posted by MaDmiZe
asf to MPG conversion
By kshavo in forum Video ConversionReplies: 1Last Post: 15th Oct 2010, 05:14 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 11:07
