i'm capturing video using pinnacle studio7, which only allows 4gb file captures. if i then add multiple files to the movie, and try to create a complete movie (greater than 4gb), which i then want to encode using tmpgenc, the prog says i can't exceed the linit..if i output the file to my camcorder i can send the whole movie..is there any way around this?...
Use a computer with Windows 2000 or Windows XP operating system and the NTFS file system.
Panasonic DMR-ES45VS, keep those discs a burnin' -
Like he said, XP or 2000 and the NTFS file system. FAT32 is what limits the file size to 4GB, NTFS has no relevant file size limit (at least 2 terabytes, gigantic).
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
If you are serious about video capturing, upgrade to Win2K or XP is a must. Even though you may have to fight compatibility problems in the beginning, the result is well worth it. There is nothing so cool as capturing a whole movie and then making a DVD. Especially if it is a good movie that has never been released on DVD
Fighting with movie segments is really such a waste of time. -
i'm running xp on fat32..if i convert to ntfs, do you know if studio7 and dvdit 2.5 PE run on this?
Yes it will, i'm running Studio7 with DC10+
I have done captures of about 20 gig
But for Studio7 get the latest drivers and update (7.13.6 i think) to get it running under XP, don't mind the warning messages you get while installing.
Rinkel
How to make AVI file to 1.4GB ?
By zovx in forum Video ConversionReplies: 2Last Post: 5th Feb 2010, 10:24 -
watermark limit on avi file
By EmpowerMaui in forum Newbie / General discussionsReplies: 2Last Post: 17th Sep 2009, 04:36 -
help -- salvaging a 4gb avi file
By pkpara in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2009, 20:50 -
Shrinking an AVI file from 1.4GB to 700MB
By DVantrease in forum Video ConversionReplies: 5Last Post: 28th Mar 2009, 19:11 -
4gb Limit on SDHC Card, FAT32
By AVCHD in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 04:24
