Trying to convert an .asf file (2hrs long) to .avi with "ASF Tools v2.30.
During conversion the log gives this error :
Opening C:\WINDOWS\Rips\movie.asf
Header Obj ID OK
Data Obj ID OK
located: File property Obj
located: Audio Stream Obj
located: Video Stream Obj
Number of Chunks: 66112
Pass 1, Analyzing...
Invalid ID: FCD38E, Chunk #28989
Invalid ID: 3F4B49, Chunk #29002
Found 66112 Chunks
Pass 2, Converting...
Chunks Discarded:2
Chunks Converted:66110
Frame rate set to:15.08364
Frames added for A/V Sync:708, 0.7% of Total:100520
File Closed.
The avi converts but suffers A/V synch problems (severe)
If I try to repair the file with ASF Tools (advanced repair tab) and select to fix bad blocks (tried on all repair options), it repair but when I convert it to MPEG with TMPEnc v12a and a few others, the sound drops after 48 minutes and TMPEnc doesn't hang but the remaining time goes up to 12hrs.
If I select standard repair in ASF Tools, then it auto trims the length to 48 minutes (presume this is where the bad chunks begin).
Does anyone know of a workaround or any util that will sucessfully repair this file....thanks in advance
Did you know the latest version of TMPGEnc will except ASF files
Well Install the Nimo codec pack to make sure you have everything it needs. TMPGEnc will handle bad frames (Sometimes)
Thanx KingJohn, will give it a try as TMPGEnc won't accept Audio past 48 minutes...
Motherboard repair
By dafoe in forum ComputerReplies: 14Last Post: 10th Mar 2012, 20:49 -
possible to repair mp4 ?
By narinos321 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Feb 2012, 15:07 -
ASF to MOV or MPEG4 problems using FFMPEGX for Mac
By Maverick101 in forum ffmpegX general discussionReplies: 3Last Post: 29th Sep 2011, 13:54 -
Computer Repair Help
By KingSeti in forum ComputerReplies: 37Last Post: 29th Nov 2009, 15:32 -
Audio Repair
By NightFire in forum AudioReplies: 11Last Post: 27th May 2008, 22:21
