Hi -
I am just wondering if this sounds normal and if there is any way to speed this up at all. I am captureing with Dazzle DVC II and their software. I edit the cap with TMPGEnc then re-encode with TMPGEnc and CBR. The re-encodeing takes about 12 hours with CBR, which is ok ... but ... I would like to use 2-pass VBR, except that it takes up to 24 hours to re-encode my 30 minute clip !!!
Thank you for your help/time
LG
My Specs:
MB: SOYO FireDragon
CPU: P4 NorthBridge 512K Cache 1.8 GHz
MEMORY: DDR 266 SDRAM 768MB PC2100 (Corsair)
VIDEO: Nvida GeForce2 GTS w/ 32MB SGRAM
IDE: UDMA Mode 5 ATA-100 7500rpm 80 Gig.
OS: WinXP PRO
encodeing does take a long time. i'm just finishing a move that took 32 hours
LiNUXG33K, your time seems a little excessive. What format are you capturing to and at what bitrate?
I have done many MPEG-1 captures at 7.5mbps and encoding to VCD using 2mbps 2-pass VBR. It usually took about 10 hours.
This week I did an AVI capture at 480x480, edited in VirtualDub and frame served to TMPGEnc encoding to SVCD using 2-pass VBR.
All of the above is using highest motion precision and the video length is 40-43 minutes (a 1hr show with the commercials removed). -
Hello -
Well, I capture to either SVCD or DVD-MPEG2. The DVD-MPEG2 is captured with VBR at 8.0 MBs and if I use SVCD it uses 2.4 MBs.
What I am trying to do is, move my VHS collection to CD's (that can play on my home DVD player) I also capture some Digital video from Sattelite.
I want to be able to have the best cap's I can without out taking over 14+ hours.
Thanks for any insight/tips
LG
[quote="jwhitlow"]LiNUXG33K, your time seems a little excessive. What format are you capturing to and at what bitrate? -
Try frame serving with avisynth to tmpeg or cce. Reduce the color and resize on the fly.
Yeah re encoding takes a long time and patience. For me, without ANY filters in TMPG, in my 500MHz celeron, it will take 8 hours per 2 hour movie.
Mmmm well 8 hours for a 2 hour movie isnt bad. Why does it
take 23 hours for me to encode a 30 minute clip ???
Using-> TMPGEnc SVCD/NTSC 2-pass VBR on a 30 minute clip
Captured at -> SVCD 480x480 8.0Mbs VBR
Help !
LG -
My guess, I used VCD standard settings. No filters, no resize, constant bitrate, one pass. Using VBR from what I understand increases time needed because it has to analyze the video to find out what areas need more data or less, than it does it all over again.
How do I speed up my video to 10X speed?
By mileena in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2010, 13:24 -
Normal or not?
By alintatoc in forum ComputerReplies: 4Last Post: 25th Mar 2009, 00:36 -
FFMPEG AVI (XVID) to IPOD Mp4, AUDIO OUTPUT is 2x Normal Speed, HELP!
By jiulonghks in forum ffmpegX general discussionReplies: 1Last Post: 20th Sep 2008, 23:35 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41 -
using a webcam, plus time-lapse software, to make a normal speed video..
By snafubaby in forum Capturing and VCRReplies: 2Last Post: 27th Apr 2008, 01:38
