Alright mateys, lookie here.
Assume that I have a particular AVI file which I have extracted from my DV Cam recording. However, due to some copyright protection limitations, the AVI file which I have extracted is completely dumb.. Or rather, mute without any sound.
Fortunately, I've managed to extract the audio that should have complemented the video into a wave file (courtesy of Total Recorder) and now I'm trying to merge the wave audio with the AVI so as to achieve an end-product which I can burn into a VCD.
I was wondering what processes and software would you all recommend in order to achieve this? Would appreciate some enlightening advice indeed, and thanks a lot beforehand ^^
Cheerio,
Theodore Massacre
If the end-product is a VCD then you can use TMPGEnc and
load your DV file and Wav file. Then encode it directly to VCD. -
Almost any video editing program can do that. For what you're describing, Adobe Premiere works great.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
Merging multiple parts of one mp4 file into one file
By vaultedskies in forum Newbie / General discussionsReplies: 2Last Post: 16th Nov 2011, 09:08 -
Merging audio file and video file using ffmpeg
By suresh3484 in forum ffmpegX general discussionReplies: 3Last Post: 17th Aug 2008, 21:20 -
Help on merging h264 and aac file
By overground55 in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2008, 13:23 -
By suresh3484 in forum ffmpegX general discussionReplies: 0Last Post: 27th May 2008, 03:05
