I would like to convert a few of my svcds to vcd in order for my friencs to be able to enjoy a few good flicks. Now, I know that there is a guide that explains how this is done, but my question (though simple) has been overlooked. See, my svcds are already on disk and the original MPEG-2 files have since been erased. A helpful friend here at VCDhelp told me that I should take the MPEG file out of the MPEGAV folder - but where do I go from there? If someone could cover this subject for me, I would appreciate it. The guide deals with MPEG-2 files being converted to vcd. My situaltion is a bit different since my file is already on a disk. Thanks in advance!
Peace,
budgirl357
Use ISOBuster to extract the file from your CD. Make sure you use the 'Extract M2F2 MPEG-2 frames only' option (will make more sense once you load up ISOBuster). This will give you a mpeg2 file that you can then convert to VCD by means of the various guides available on this site.
copy the mpg file from the disk to your hd then u can do 1 of 2 things
1 load up dvd2avi and file open select mpg file and ok
save project u will b left with a .d2v (video) and an .mpa (Audio) file
oad them up in tmpgenc and encode to vcd
2 in tmpgenc goto mpgtools and demultiplex load the mpg up and save the video and audio (double click each stream). Then load them up in tmpgenc and encode to vcd
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 02:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 22:10 -
question about how to remove simple software
By jimdagys in forum ComputerReplies: 2Last Post: 10th Apr 2008, 12:15 -
Embarassingly simple capture question
By eclipse95 in forum Capturing and VCRReplies: 5Last Post: 16th Nov 2007, 14:12 -
another simple question about FCE and iDVD... =)
By ednarophati in forum MacReplies: 1Last Post: 31st Jul 2007, 11:15
