I've got a DivX, that's currently on 2 CD's 90mins on each, is it possible to convert this to 3 VCD's, about 60mins each ?
I've downloaded the tools from the Convert section, but I'm stuck onone thing.
If I convert the first 60mins to CD1, then how do I convert the last 30mins of disc 1 and the 1st 30 mins of disc 2 to CD2 or ins't that possible ?
Panther
All say Grrrrrrrrrr...................... -
You have a couple of way to do this. What I do is encode the two Divx files to mpeg. Then cut the two file into four parts. Putting frst file onto 1 cd then the two smaller files onto 2 cd then last big file onto cd 3. Or you could join the Divx and then encode the new file then cut into 3 parts. Look to the left under how to edit. 8)
May the force be with you. -
Join them with TMPGE...then Batch Encode with TMPGE cutting it into an even 3 parts on the fly.
"Today is only yesterdays tomorrow" -
sorry...made a booboo...if its a Divx...join it with Virtualdub
Not too difficult, "From Internet&DV to VCD" will be your good assistnat
) You can download it from the F389ree Download A2rea of www.j23u3m34mp39a.com
Hey, you must delete all of numerals in the text, if you really wanna visit this web url or get this program
Help needed Converting to AVCHD to play on Panasonic TV
By LOWTECH in forum Video ConversionReplies: 8Last Post: 31st Aug 2011, 12:52 -
help needed converting and editing an flv please
By Witzend in forum Newbie / General discussionsReplies: 6Last Post: 23rd Aug 2011, 15:04 -
trouble converting/xb360 essential settings needed
By Captain Slow in forum Newbie / General discussionsReplies: 8Last Post: 17th May 2011, 19:14 -
Help converting YUV420 to RGB565 needed
By cheetahace in forum ProgrammingReplies: 3Last Post: 18th Apr 2008, 02:15 -
DivX file needed
By Tbag in forum ComputerReplies: 2Last Post: 25th Oct 2007, 16:35
