Is there anyway I can convert like a 650MB AVI file to an Mpeg around the same size so I can keep it on one disc. Or make it into a SVCD (doesnt make a difference)...Just as long as I can keep the VCD or SVCD to one disc.
Results 1 to 12 of 12
Sure,
As long as the length of the movie is under 80 minutes, it will fit on one CD in VCD. Movies up to 99 minutes can be done with a burner that has good overburning. -
yea but lets say I convert the 650MB avi to mpreg...its gonna be atleast over 1 gig...and u cant burn 1 gig to a cd no matter how long the movie is...
Someone pleas correct me if I'm wrong, but wouldn't MPEG compression make your file size smaller compared to AVI format?
Divx files typically encode to bigger files in MPEG1/VCD. You can make a nonstandard VCD (xVCD) with lower bitrates or make a 2 disc movie.
Panasonic DMR-ES45VS, keep those discs a burnin' -
With VCD's the movie total time is the limit NOT so much the file size.
Originally Posted by SoLuTiOn86 -
NO !Originally Posted by SoLuTiOn86
No if you still want to watch it...
The DivX AVI will typically be half the size of a mpeg1 mpeg2
Converting Divx to AVI with a Twist
By Deathbot70 in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2012, 12:42 -
Help/Advice Converting .AVI Divx Files To ...
By MourningStar in forum Video ConversionReplies: 2Last Post: 12th Dec 2009, 16:18 -
Converting a Home DVD to AVI - but not divx?
By sterankin in forum Video ConversionReplies: 4Last Post: 16th Feb 2008, 11:52 -
best software for converting dvd to avi, divx etc ???
By geronemo in forum Newbie / General discussionsReplies: 4Last Post: 15th Nov 2007, 12:48 -
Converting ISO to AVI (Divx or Xvid)
By cyberjackal in forum Video ConversionReplies: 2Last Post: 11th Jul 2007, 10:50
