I want to get DVD menus on a VCD, like play movie scene selection..etc. I tried SpruceUp, but that didnt seem to load any of my VCD or SVCD movies....So then I tried Ulead DVD and I loved it except u can only do scene selections and nothing else. Are there any other programs that will do what I want to do? Also why aren't my movies loading in SpruceUp, they start goign and then just stop and don't show up in the side menu...is it cuz they aren't DVD?
DVDit Will work for you, just do a search for a site that has the Demo, the Sonic site does not have the Demo, but it is out, just don't remember where.
You can use a number of search engines, Kazza, Bearshare, ete........
Aloha
Bud -
O SHia I forgot about that, I went to the site and the downloads were down, and then i forgot to search...Thanks alot
Use Kazaa, they have the demo version there, it might be a version behind though.
You're not really going into an astroid field are you?!?
They'd have to be crazy to follow me! -
OK I got the program and made a menu and everything...but its telling me the disc capacity is too big and it wont hold it...Its like 800 mb on a 700mb cd...but its way under the time limit....shouldnt it just overburn it?
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 02:44 -
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 15:28 -
Question about audio conversion to put VCDs on DVD
By jimdagys in forum Video ConversionReplies: 5Last Post: 28th Sep 2008, 22:07 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 02:52 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 10:07
