When I open a VOB file larger than 1GB, the opened process only access the amount of frames corresponding to 1GB.
Why?
I never had a .vob, that was larger than 1gig. At http://www.doom9.org I saw a tool called vobSplit. Maybe you should try that.
did not know you can open a vob file within TMPGEnc. i just tried it (using 12h) and it said that a few DLL files were missing and that the format is not supported.
Do I need any other file to encode vob to mpeg using TMPGEnc.
I use Flask to BBMpeg to TMPGEnc to rip a DVD to mpeg2. -
I used it once for audio conversion (musik dvd-->mp3). But actually this is not the usually way.
arivan, why do you want to open a .vob in TMPG? Use dvd2avi instead. -
For opening VOB files you need to install some mediashow filters?, the ones with .ax extension. But I am not sure.
I use SMART RIPPER to rip DVD files to one big VOB with only the audio track I want, so I can directly encode with TMPGEnc. But there's this strange barrier that only allows me to encode 1GB.
I forgot to mention:
I use TMPGEnc to encode DVDs to SVCDS to play in my PIONEER DV_535. It does it really fine. -
dunno...the vobs smartripper rips r over 1 gig...but u're suppose to create project .d2v file w/ dvd2avi...so tempgenc doesn't have to deal w/ the vobs directly...just load .d2v file into tempgenc...and tempgenc will use .d2v file to find the vobs and use it to encode the video portion of yer SVCD
how can i reender a video with HD quality and around 1gb 4 each hour???
By khalid81 in forum EditingReplies: 9Last Post: 24th Oct 2009, 14:55 -
Ifoedit, vobs have to be not less than a 1gb?
By Remyisme in forum Newbie / General discussionsReplies: 4Last Post: 25th Oct 2008, 06:12 -
4 1GB VOBs - how to make a dvd?
By texas1 in forum Authoring (DVD)Replies: 1Last Post: 15th Nov 2007, 22:44 -
TMPGENC wont accept an mpeg :S
By chocolate_brownie in forum EditingReplies: 4Last Post: 7th Aug 2007, 18:34 -
Want to make 1GB ASF smaller
By jabroni in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2007, 00:01
