Hello
I need some help with converting a DivX-movie to SVCD with TMPGEnc. I know the basic and I´ve made one movie with the wizard but I understand that you can do a lot more with the program.
I want to have the movie in PAL-format, but I don´t know which format I should use 4:3 625 Line PAL (704*576), 4:3 625 Line PAL, 16:9 625 Line PAL or 16:9 Display.
What settings is the best?
Is there any good guideor FAQ for this program that I´ve missed?
/TheCollector
For best results you should maintain the framerate, ie only use a PAL template if the source is 25fps. Also, for DivX the source aspect ratio should be 1:1(VGA).
converting Divx to QT?
By rotuts in forum MacReplies: 3Last Post: 17th Jul 2008, 16:28 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 23rd Feb 2008, 23:35 -
Converting DivX to HD
By CFCproductions in forum Video ConversionReplies: 6Last Post: 18th Jan 2008, 14:11 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
