I'm ripping the DVD with SmartRipper v2.34 and I get a file where there is info about where the chapters begin (in frames). My question is if there is a program that can cut a movie after a list like the one in the file.
ex. A program where you load your movie, add points (in frames) where you want the movie to be cutted and press 'Cut'.
use adobe premiere
, you ned a plugin so you can work with the mpg1 (vcd) format
Do you want to make (S)VCD? Did you encode already? Then try TSCV by http://www.ttool.org and have a look at this topic: http://www.vcdhelp.com/phpBB/viewtopic.php?topic=52872&forum=1
This is a VCDImager GUI. You need VCDImager v.0.7.x.
http://www.hvrlab.org/~hvr/vcdimager/
What is the best way to cut up an Xvid file or add chapters to it?
By Chrushev in forum Newbie / General discussionsReplies: 2Last Post: 29th Mar 2010, 05:14 -
Cut and Join VCD Files: tools that can Handle that
By devilcoelhodog in forum Authoring (VCD/SVCD)Replies: 5Last Post: 15th Jan 2010, 21:57 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 11:36 -
870211 - vcd cut
By hamidi2 in forum Newbie / General discussionsReplies: 2Last Post: 30th Apr 2008, 03:55 -
How do i author dvd menu with chapters + cut commericals...with a WMV??
By chocolate_brownie in forum Authoring (DVD)Replies: 0Last Post: 2nd Jun 2007, 19:00
